- Banned
- #21
Hrvoje Simic
Banned
Mixed lighting do screw up things for any camera, but Alexa seem to manage it much better. Whenever I've graded Alexa footage with mixed lighting I've never really had that much of a problem, but it's always a struggle with Dragon.
I've had those issues in post with many cameras, and yes even Alexa. That is normal. Different light sources cover the visible spectum differently and when mixed and reflected off the skin cause unnatural color response which very sensitive high precision cameras can capture and brain in real life ignores/"irons" interpretatively.
Alexa "chokes" colors in a specific way, which can make some of those factors be less visible but doesn't remove them and still does have its trainwreck color situations with mixed light scenarios. I've had to correct them.
If, theoretically, you could just emulate Alexa response from the start you'd condition and limit the performance of this sensor. If a different path is used it can still look excellent and natural/organic.
Here's two others. The original look is how Dragon looks through the RWG / Log3G10 with 709 Lut (it's a work in progress from Graeme) together with a node that blocks saturation at the shadow/highlight extremes. The tweaked is the same but with changed balance values for reds and yellows together with some experimentation with luma vs sat.
RWG / Log3G10 - 709LUT
RWG / Log3G10 - Tweak - 709LUT
First one seems more technically accurate, second one closer to your liking. Camera focused color scientist cannot chase the second one because that would necessitate reduction of image accuracy and more push towards a creative look.
