Kirk.Attard
To be honest I think Ill just wait for the schneider and see if I can sell this one. Really interested in that set since Phil reviewed them. They have interchangeable mounts. Was looking for that apart the breathing.
Hi All.
Concerning image quality I might have been a little disappointed. Though sharp it kinda looks a little like my Nikon prime which doesn't cost much more than a couple of hundred bucks. I'm not saying its bad and I still have to test it further in good lighting conditions but that was my first impression. Focusing was easy though as the throw is good and you hit the mark easily so no problems there.
There are three Mutars in the Contax Line:
MUTAR I (2x) (use btw 45mm to 135mm, approx)
MUTAR II (2x) (use btw 135mm to 500mm, approx)
MUTAR III (1.5)
I've read of people having success with BOTH Mutar 2x on the 100-300.
The thing to be careful of is the rear element on the zoom, which will HIT the Mutar if you zoom down to 100. My assumption would be to keep the zoom between 200 and 300 to be safe.
Also, here's full list the specific lenses that work best with each Mutar 2x (think David shared the same pdf!):
http://lenses.zeiss.com/content/dam...nloadcenter/contax_yashica/mutari-ii_2x_e.pdf
Here is a quick still taken when I first setup the lens. Wide open. Natural lighting only - Just some slight curve on the image - NO touching otherwise. Will try to properly test the lens out this week.
So I did put together Mutar II X2 and the 100/300
Quiet promising so far,
I nailed some CA at 600mm thought (in harsh circonstencies)
Mutar II X2+ 100/300 @ 300 (some CA on the left back ground)
But the thing I really want to try next week is a shot of the full moon.
Best
B.
Can't believe you caught a hawk with a worm. Fantastic. I wonder if the Mutar and extra glass is making the CA flare?
MUTAR III (1.5)
Hi Guys,
I have not yet tried this, but what happens if you use a Canon 1.4X or 2X extender with an EF mount adapted Contax lens rather than a Mutar? Does it cause a shift in colors? Or, is there any other negative effects? Obivously what I am thinking is once a lens is adapted for EF, it is difficult or impossible to use the Mutar depending on the permanancy of the adaptor or mount.
Thanks,
Tom
Hey guys, heres my reel shot on 95% contax zeiss lenses with Scarlet.
I tried to use my set of Contax glass on my new 5dMkII the other day, and ran into lens check error issues, which I believe are due to the chipped adapters I am using. Of course they have worked flawlessly on every EF mount camera I have used up until this new MKIII.
Ideas?
Thanks!
Dave
Ideas?
Thanks!
Dave
This thread is such an addiction enabler...
