Dillon Novak
Active member
- Sep 15, 2008
We shot 4K MX with a 2:1 ratio. We rendered out 1080P prores clips for editing in FCP and everything has been fine in the edit. We put the "_H"s on all of the prores clips. But just recently, when attempting to grade a teaser for our music video, I exported an EDL file from FCP. I imported it to Color with the exact same settings that the FCP timeline had, but it says something like "Color had problems importing some of your clips, there may have been intersecting timecodes".
So once I get past that warning, I see that two clips from the teaser are different in Color's timeline. I can edit the footage in the RED tab, so I know that it's connecting to the R3D files.
I remember on set, we filmed band the first day and story the next day. When filming story, we were swapping out to our second drive and it was not formatted. So it continued on the same reel A004_..... file name as the band shots from the day before, rather than being A006_.... in chronological order of shooting.
I looked into it further and imported an EDL of the full video in Color and found that it is Story clips in A004_....that are being improperly connected to band clips from that same reel that were already on that drive.
Is this my problem? Would there be any way to fix this? I'm totally stuck.
I also know that in RED Cine, for the band shots I accidently rendered the footage out with full on all of the debayer settings I realized this before rendering out the story clips and then changed the debayer to
2k-1/2 good
3k- 1/2 good
4k- 1/4
I don't know if this would cause anything, but just trying to give as much info as possible.
Thank you very much; anything helps.
2k-1/2 good
3k- 1/2 good
4k- 1/4
