Clip Finder and RED Alert works wonderfully together
Can someone help? I have the latest RA, Clipfinder, FCP, OSx, Mac Intel, etc. I have turned on the System pref for access like Clipfinder Help says to do and I cannot get the clips from Clipfinder to open in RA as the original poster says. I even tried Clipfinder Edit Open in RA. I did the XML from FCP to Clipfinder. Why won't these clips open in RA as described in this thread?
Gary
Gary,
Does this problem only occur with the clips you imported from the FCP XML file or does it also happen when you import clips from .RDC directories ?
If it happens only with clips imported from FCP, then check the icons in the list of clips in Clipfinder.
If the icon says "MOV" (and not "R3D") then the FCP edit used clips transcoded to Quicktime.
REDAlert cannot edit those.
However, you can use the "Replace .MOV with .R3D" function in Clipfinder to get back to the original R3D clips and then grade those on REDAlert.
If this is all obvious to you, I'm sorry, and I would ask you to let me know so I can to work with you to fix the problem.
Hans
Hans,
All your suggestions worked.
Thank you,
Gary
