Milan Nikolic
- Dec 30, 2006
I experienced CODEC FAULT only when filming in the bright sun situation. I am shutting 4K, 16:9, build 15 and redcode 28.
Two years later... in 2010...
We are having a CODEC FAULT problems after recording about 10-30 minutes about every third shot. Settings are 4kHD, 30fps, Max on, Red Code 36, Build 21 v21.4.1. Shooting outside, so it is always sunny, not necessarily hot. All the bad shots have minimum of sky in them, so compression data rate is high. We are shooting on 640gb RED drives with wide angle lens 25mm Master Prime, everything sharp (which is a must).
I will try lowering to Red Code 28 and turn Max setting off. Any other ideas in what I can do? Deep format hard drives? I did have few dropped frames today.
