Build 16... taste
EDIT: So i just re-read your original post, and it seems you did state that you made no adjustments. Hmmm, then what I am doing wrong that my footage looks so grainy at above 1000 ISO?
When you said "each one adjusted 1/3rd stop to match the corresponding ISO.", what does that mean? Meaning you were stopping down the lens as you bumped the ISO?
Make a similar setup. Use daylight (tungsten does not yield the same results for obvious reasons). Stop down your lens as you raise ISO. Use curves to match outputs as needed. Nothing else. Just make SURE your original exposure is NOT under-exposed. That is usually the killer.
I have done this a number of times and get the same results with different setups. No de-noise used.
If your exposure is right and you are getting different results (more noise) the other culprit is usually that your low light condition is not "daylight balanced".
Jim
