Matt Paul Catalano
Active member
I have a specific need to shoot extremely wide (15mm or less on a full frame) on the Epic-W at high FPS (90-120fps) in 5K or 4K. As you know the sensor gets cropped as Red doesn't offer any other option to line skip or average pixels together for quality purposes.
Does anyone have any ideas for 3rd party lens mounts or adapters that might let me put a C-Mount lens (or similar) on the Epic-W and get the lens closer to the sensor creating a smaller image circle? Is there any type of C-Mount to PL mount adapter or any other combination?
Alternatively, does anyone know any extremely wide lenses that don't have too much distortion near the center? The widest fisheye I can find is about 5-8mm. After its cropped to 4K it will be about 12-20mm. Some fisheye lenses might not be too bad once they're cropped. It's mostly for shooting in the ocean inside waves so the distortion in the corners won't be too noticeable.
Also on the rectilinear side of things the widest I see available is 11-12mm. Any suggestions in that realm?
