Sanjin Jukic
- Dec 28, 2006
- Vienna, Austria
- www.sanjinjukic.com
BeBob Rouge is a real RED1 "power" game changer.
Works perfect!!!
"The BeBob ML-120 is a Hot Swap Adapter for the Red One Camera allows a change of batteries without interruption of the power to the camera".
Now my RED1 can work non-stop 24 hours/7 days with just two RED POWER PACKs (2 chargers+4 batteries) or any other RED1 compatible batteries.
"When the battery runs empty, the ML-120 will take over the powering of
the camera for 2 Minutes, at the same time giving a simultaneous alarm.
During the first 90 seconds the ML-120 Alarm LED will flash RED,
for the next 30 seconds the LED will display as a continuous solid RED.
After 2 minuets (120 Seconds) the camera will switch off.
The ML-120 replaces the Standard V-mount on the RED Drive cradle, or
other 3rd party battery mounts. Additionally, it features a 12 V DC D-Tap
port, secured by a 5 A self-resetting fuse.
After use the ML-120 self-charges from the regular camera battery and
will be fully charged within 40 minuets, the capacity of the ML-120 allows
for 5 x 2 minuet run times, with its self-charging system the ML-120
requires no further operator maintenance or interaction
When used with Red compatible batteries (RED Block, bebob) the
ML-120 transfers battery-data to the screen of the camera to display
remaining battery capacity information.
Features:
- 2 Step Empty battery-alarm
- 20 Wh built-in Power-buffer
- Automatic switching by empty batteries to allow continuous powering of the camera
- 12 V D-Tap Port with self-resetting 5 A Fuse
- High-End V-Mount Plate to avoid possible poor contact between battery and camera
- Only 360 g"
From BeBob ML-120 User Manual>>>
BeBob Rouge ML-120 fixed on RED QUICKPLATE that attached with ET SpeedyClamp/19mm rod on RED1.
Works perfect!!!
Features:
- Only 360 g"
