Joseph Ward
- Mar 27, 2007
Any idea when Audio specs will be out?
What are the differences from the old and new board? Its 24bit/48kHz, 24/96, 24/48? Digital/Analog, new i/Pins? Whatever you can say or when will you guys release the date for specs?
With the new audio upgrade, can I use pro mics and cables plugged directly into Red and get a sound quality good enough for a feature "indie" movie
Another audio newbie here.
With the new audio upgrade, can I use (get away with) pro mics and cables plugged directly into Red and get a sound quality good enough for a feature "indie" movie or do I still need a field mixer like sound devices 302 or 442?
Its the same overall "spec" ( 24-bit 48 Khz ) but the performance is substantially better as a result of the following -
Clean phantom power
Clean mic pre-amps
Adjusted inputs levels (same as with old board with special cables)
Improved line out and microphone output
This project is sync sound and they have no desire to use the mono mix camera audio for anything but scratch track for rushes. I was also told that the on camera audio sync seems to still be off +/- 2 or 3 frames.
several 3rd party tests have show that the RED does not record in full 24bit and that it is less the 16bit when analyzed through any pro audio programs..
We seem to be experiencing a rare audio problem.
Audio is going through a mixer and then into both cameras via Red mini-XLR adapters--line level. Playing a clip back through the camera plays picture and audio fine on both cameras. Going into RedAlert or RedCine the datatech can't get ANY audio to play from the QT proxies on one of the cameras.
Stuart,Commented elsewhere on this, its possible the mixer or the input cables are phase inverting the audio. If they are, you wouldn't notice that on the camera PPM meters, or when listening to the camera recorded sound via headphones.
Taking the recording to QT Player, if one of the signal's phases are out, it will cancel, so any audio level adjustment (which affects both channels) will have no apparent effect.
You could check your input phase setup by recording the same line signal to channels 1 and 3, or 2 and 4. Then put the HEADPHONE output as QUAD MIX. Then you should either hear a louder signal or none in the headphones.
