Brandon Kelly
Hey everyone,
So I have had my audio kit for a little while now, and it seems to produce pretty nice sound for when we can't have a dedicated audio guy around. I have been researching and researching trying to dial in my kit and make sure I have the correct pipeline running and my mind is going crazy.
Rode NTG3, Sound devices MM!, variable attenuator, zoom h5
I have been running the mic into the mm1, then the attenuator at -10 to -20 db out of that into the zoom, with either a single xlr, or an xlr y adapter. I also have 1/4" TRS adapters for into the zoom, as Ive heard it will help bypass the zooms preamp.
I did a lot of tests yesterday trying to get the best audio possible but any suggestions would be great. The sound device boosts the mic and turns the level to a line level out. The zoom accepts both mic and line level it says, but doesn't a switch to choose.
I was testing with lower gains on the SD, and no attenuator. Slightly higher gains on the SD with atten. I tried mic straight into zoom, which actually sounded really good I just had to turn the knobs up a bit, so if the mic was a bit further away that might cause issues cranking the zoom pre, I triead all of the above with and without the 1/4 TRS.
What would be the correct pipeline, I just want to get the best audio I can with what I have.
