Benjamin Zimbric
- Dec 30, 2008
Cannot get audio to record or show up on the camera. I have an innocinema xlr to mini jack adapter. Checked out the continuity of the audio connections and they are good. Also checked out the wiring assignments. They are good according to the diagram I found on reduser.net. When audio recording is enabled tracks 1 and two light up and the indicator dots go green indicating that something is plugged in. However no levels show up. Tone of both line and mic level don't do anything to the level meters. Nothing comes through the audio output. I also tried putting audio through an old beachtek xlr to mini jack box I have. Nothing there either. There is no sound in the camera. Adjusted outputs, inputs, framerates, resolutions, nothing changes it. The little green lights just stare. Need a solution ASAP. Thanks.
