Patrick Tresch
The camera has internal denoise but who cares?
Doubtful, he works so much with splits, stabilizations, and VFX reframing that 4.5K won't cut it. I think it's probably guaranteed that he'll work with the Raptor for now.
So it's an light hungry sensor who still struggle with noise.
Wich should be present in the normal low iso mode, if you push the 4 lowest stops of those17.
CVP conducted an OVER/UNDER test and at 7-1/3rd Stops over it held on to color without clipping also very well. The shadows did look a little bit better than some previous tests I've seen but not a major improvement (CVP review video from about the 9:51 to 12:17 minute marks)
Honestly why would you choose the LF over the 35? I can't think of a single reason. I can't even think why anyone would choose the 65 over the 35.With the first Keynote speaker, he said that the LF will be around for at least another 2 to 3 years
Imagine what Red will come up with by then!This is correct. They will need to do something rather different to scale this up in 2-3 years.
