Björn Benckert
Pretty much the way I am thinking now.
Thanks for validating the approach, and more interesting insights, master Phil.
That's an easy answer. If you lower the ISO, you know that you are not changing the amount of light that hits the sensor, and you are not changing the quality of the image, as it is exposed properly already. You already know there is no degradation in quality by moving a stop down from 800. You are just showing the director how it will look once "pulled", or printed down, or however you want to call it.
Let's make it more interesting. Same scenario of above, but now the directors tells you that the image is too dark overall. What do you do?
Iso is a number for digital gain. Digital gain = noise. So the real question is, how much noise do you allow your image to have. If you dont have a problem with higher noise levels then what your current iso provide, then you can just bring up the iso if the director ask for a brighter image. If you dont accept higher noise levels then you need to change some other parameter, the amount of light, iris or exposure time.
