Mark L. Pederson
REDuser Sponsor
yes absolutely as fast and easy to get as deep into the image as possible,
that would mean you scrub through a take on set, in REDCINE or QUICKTIME or what.
Okay, I was just thinking this through while at the Apple store on 59th Street changing a bogus laptop battery.
FORGET what I said about a seperate app -
YOU SHOULD BE ABLE TO SEE PIXEL FOR PIXEL IN 4K IN REDCINE -
You could PLAY in RT on set in a proxy extraction (1K should work fine on a Mac Book Pro) - but you can SCRUB the actual 4K REDCODE RAW in REDCINE, and make your adjustments - look at the highlight and shadow detail, etc. - so, as long as REDCINE can display the 4K image in "ACTUAL SIZE", pixel fo pixel - and you can move the image around to see all of it in full res - then we are all golden - everything we need on set in REDCINE - and I would not be surprised if that is already the case - if not, should not be much code to fix -
so dismiss my earlier posts!
