Gabriel Przybysz 2
Active member
- Jan 26, 2013
Exactly - no possibilities to get worse image by professional anamorph... - it could be not so sharp (usually is) but ALWAYS beauty
At this point, shooting ana from 16:9 sensors vs. 4:3 has more to do with field-of-view than resolution if you ask me.
I tested out my new Epic with my anamorphic lens (panasonic la7200) last night and was also confused at how much resolution was lost. I see no reason why anyone would use this option in lieu of simply rolling in 5k and squeezing yourself in post. What am I missing?
I never meant to suggest that my anamorphic lens was of top quality, nor was I questioning the reasons why one would shoot anamorphic or not. I was simply asking why use the ANA 5K mode instead of simply shooting anamorphic in 5K and then squeezing it manually in post?
I've shot many projects with my anamorphic lens on the 5D that have come out satisfactory by my standards (even on my Scarlet too: http://vimeo.com/m/62218014 ), all of which were shot in a normal sensor mode and then squeezed in post. Why would I want to shoot with less resolution to work with and thus cropping my image? I'm just confused about this, I think I'm not understanding what the cropping achieves.
Your Panasonic adaptor has a 1.3X squeeze so you don't really have to do much cropping or any to achieve 2.40 if you record 16x9.
A standard 2X anamorphic lens will create a 3.56 : 1 image once stretched back out horizontally if you record 16x9 on the Epic, so cropping it is inevitable to get back to 2.40 -- the reason you crop it in camera using ANA mode is that the monitor outputs on set will be desqueezed and you are reducing the amount of data to record -- why not since you have to crop it anyway? You won't be gaining resolution by not cropping in camera if you have to crop it in post anyway to get back to 2.40.
