Tom Lowe
- Jan 5, 2007
Is it more difficult to shoot long-lens footage, at say 300 - 400mm, in 3D? For example, if your intention was to film long-lens wildlife footage in 3D?
The 3D IMAX movie "Wings of Courage" shot telephoto stuff with a single camera and copied the same 2D image for the other "eye"... because basically the interocular distance between the eyes doesn't matter when an object is extremely far away, there is no stereo effect in real life with distant objects.
3D photography sort of demands that you work at "normal" subject distances for the most realistic effect, rather than extreme wide-angle and telephoto images that are not like the way people see things. If the whole point of 3D is to create a "you are there" experience, you'd want to keep to shots that seem like they could be a human's perspective onto the scene, even if from extremely high or low angles, etc.
Is the idea that the farther away an object is, the wider the separation needs to be between cameras? Let's say you wanted to film a crocodile chomping a wildebeest from like 200 feet away, could you build some kind of crazy rig with the cameras spaced 15 feet apart or something like that? Maybe put them on a slider and use laser range finders to establish the distance, as was mentioned above?
Why? Focal length also affects 3d "volume". A long lens will ten to flatten objects a term in 3D we call "cardboarding" you will end up with a image that looks like a pop-up book.
Wide lenses will tend to make things more "round" and give them more "volume".
Also certain focal lengths + certain interocular combination's can result in "giantisim" and "miniaturization". This of course is an effect that can be done on purpose given the proper circumstances. Also if you are forced to use certain combination's there are some tricks to avoid some stereoscopic problems, mostly dealing with camera movement and background relationships.
3D can be tricky......hehe......
Generally wider lenses will be the most used lenses in a 3D filmakers toolbox.
or shoot a master framed through a doorway or window, or reflected in a mirror.
