Michael.B
85mm is super-wide in 617, normal in 645, mild tele in FF35, tele in S35 and long tele in 2/3".
Jim
An 85mm lens that's super wide. That's awesome.
Jim
All of RED's lenses will "work" with FF35. If you are saying that it will cover the entire FF35 frame, then I'm not so sure. Have you tested to verify this? Or are you simply operating on the assumption that this lens is a re-housed FF still lens and that RED has made no modifications that would affect its coverage?
Hi,
It seems like RED will offer an S35 crop on the FF sensors so that you can also work in the familiar S35 frame size, DOF and use the normal S35 PL mount lenses from RED, Cooke, Arri, etc.
One should also note that on the ANGENIEUX OPTIMO 24 - 290 - they have a 1.4x extender that will cover FF35 sensor - according to my calculations. I think they designed that 1.4x for use on the Dalsa actually - not 100% sure.
This is not necessarily true. An extender is designed to magnify the image but only for the format it is engineered for use with. For instance, we have lens doublers for both Super-16 and 35mm. I tried just what you are thinking in testing for the Phantom 65 and discovered some lenses and doublers will work and others will not. Don't know what would work on FF35.
What he said.
But you can use a multiplier to cover a larger format but at the risk of multiplying what ever abberations that are inherent in the original lens.
understood Chuck - just mentioning the option.The use of extenders to cover larger formats goes way back. We did it in the sixties using an Angenieux 12-240mm lens designed for 16mm format to cover 35mm cine format. In the late eighties I had a custom optical group designed for the Cooke 20-100 and the 20-60mm lenses to cover the 65mm format for the "Showscan" cameras. It's nothing new.
The reasonable speculation has always been that the red 18-50 is based on the sigma 18-50 which is NOT a full frame lens - it is designed to cover aps-c which also happens to be very close to S35.
Oh, and one other quick thing so everyone is clear, the reservation number you had for your lens is your place in line. For example, if you are 18Z-000222, you are 222nd in line for the lens. It does NOT mean that you will get lens serial number 18Z-000222. In fact, the serial number scheme for the RED PRO 18-85 is a totally different format so it is not even a remote option to get that serial number
Thanks, BC
I was just questioning Stephen since he stated so matter-of-factly that the lens would indeed cover FF35. .
Hi Jeff,
I made a mistake, it had been a long day!
