- Banned
- #61
Correct - if we scale in-camera for a high quality 1920 x 1080 output we should crop, then scale 2:1 - i.e. from 3840 x 2160 RAW to 1920 x 1080 progressive RGB. Or, without cropping, you could create 2048 x 1152 RGB from 4096 x 2304 RAW. Hence the 2K comments last year.
Although other scaling factors could be applied, you would introduce scaling artifacts that would detract from the whole purpose 1080p output is being requested for.
So which one is preferred....?Correct - if we scale in-camera for a high quality 1920 x 1080 output we should crop, then scale 2:1 - i.e. from 3840 x 2160 RAW to 1920 x 1080 progressive RGB. Or, without cropping, you could create 2048 x 1152 RGB from 4096 x 2304 RAW. Hence the 2K comments last year..
2. HDMI/HDSDI monitoring outputs are fixed at 720p. This is because 720p is the only single link HDSDI video format that allows us to show every frame rate up through 60fps (or 120fps).
3. You can also use the Dual-Link HD-SDI output for 1080p monitoring. For 4:2:2 color space, only one link of the Dual-Link is necessary. (The 1080p/60 format is supported under SMPTE dual link specs .....)
The phrase "Dual-link HD-SDI" can mean one or both of two things - RED can support both.
a) Use of two links to provide 4:4:4 RGB monitoring at 1080p or -
b) Two duplicate outputs of 4:2:2 YUV (Y,Cr,Cb) at 720p or 1080i or 1080p.
Stuart,
Are you saying that 3840 x 2160 could be "sampled", then scaled to 1920 x 1080? This would mean nearly the depth of field and the field of view of 35mm... at 1080. Okay, that right there would be cause for celebration!
Would the final signal be 1080p RGB only? Or could there be an option for 1080p RAW as well?
As I see it, the ideal 1080 workflow would be 1080p RAW that has been scaled from a resolution that is close to the full sensor. Nearly all the benefits the Red has to offer, at a resolution that can be more easily handled by NLE's.
No more groaning from clients when you tell them you need to charge for *days* of transcoding...
-Thor
That is a correct statement.
To expand on that, HD Preview always is 720p (with lookaround), but the dual link output could be 1080p - but only when recording 1080 RGB.
As always, the above statements are subject to change - we may yet find a way of doing things even smarter :matrix:
damn about no 1080p out thou....cough!!
coming...
Build 16 has 1080P in-camera playback now.
The roadmap is single link HD-SDI 1080P at 4:2:2- true progressive and dual link HD-SDI 1080P 4:4:4 true progressive.
All recorders or end monitors must support 1080P true progressive...
Jim
Well ladies...everyone hates a smart-@rse..but tie me to an ant's nest and smear my balls in honey if I ain't right on this one.
..oh wait, you've already done that.
Looking good so far....
Dave
I believe from Jim's comment's you have found a way of doing things smarter... dual link without 1080 RGB recording.
