1000FPS 4K Red Dragon
  • Hell yes!
    Votes: 267 68.1%
  • No, high FPS is overrated
    Votes: 28 7.1%
  • No, too expensive
    Votes: 97 24.7%
  • Total voters
    392
I've been shooting with a toy camera at 240fps and it really is a lot of fun (in spite of the dreadful quality)
I think it's an interesting idea to have a high speed head. Panasonic have just gone down this route with their new Varicam setup of course. It means you would just have to buy a high speed head and presumably all your existing Epic stuff would continue to work with it!
One thing it would definitely, definitely need tho is not just burst mode but cache recording, so you can hit record and dump out the previous 10 seconds or whatever.
One thing that drives me a bit nuts with my toy camera is being locked out of the camera while it writes to disk as you can be sure that is when something is going to happen!
Dunno it seems like a good idea, but then I'm not in the market for one right now!
It doesn't help that I don't have an Epic of course! :)
Freya
I'd really appreciate and use a burst mode implemented in actual cameras. If you're going to produce another camera, I'd much prefer if you were going smaller (good DR and redcode in a lighter body that can shoot 1h+ with 1 Redvolt)
I don't think that's possible due to bandwidth, ASIC, size and other limitations. Dragon has about 2 Gigapixel p/s bandwidth whereas the 4K Phantom has 8+ Gigapixel p/s. More bandwidth means more heat, bigger heatsinks and (probably) a bigger body. ASICs would need to be upgraded aswell to handle data compression if they want sustained high FPS.
impossible....
hahahhaaaaa.... You crack me up :)
Forget 1000, How about 500FFS burst for 6 seconds... Every-time I shoot 1000fps, I always end up speeding it up to x2 to 500 so I can see the picture move.
Good old Twixtor has saved my arse many times.
This is an important poll... I hope everyone partakes in it.
IMPORTANT POLL is an understatement.
Phantom cameras drive me nuts, I cringe ever time the producer says we need "SUPER SLOW MOTION" and its not because of the Phantom sensor or image quality, its just that it takes so fucking long to push the files through quickly onset and off set... HATE IT !
Jarred, if you make a 1000 - 2000 fps 4k Camera for 25k, I'll buy two off you as pre-sale.
If you built a SUPER DUPER 6k on steroids DRAGON HIGH SPEED and charged 50k each, I'd buy 4 off you tomorrow.
If you did a 1000 or 500 fps 10sec burst mode update (firmware or hardware) and charged us for it. I'd happily throw money at you.
So glad you guys are thinking about this.
It would make your cameras unbeatable.
If they ever get the 4k flex bugs sorted it wouldn't be such a hassle on set, but the fact that all the apps for their models have consistently worked bad for years leaves little hope. If resolve 11 works, great, but at this point its been such a nightmare for me/others I talk to.
But if they ever get the prores working in the flex 4k it will solve many of the workflow problems... just have to settle for baked in footage though. But hey, at least the files will play and be there and work in any app! theres always that lol!
what scares me the most is when I hear about missing takes on the new flex 4k. Thats not a good thing to be hearing from a DP that just used one last week... when the week before you couldn't even make Seance function yourself in a relaxed class room environment, I imagine on set with it must be even crazier right now. Also helicopters blow them up fyi if you don't watch the power...
240-300fps burst mode even for 8-10sec in 4-5k is plenty for my needs. Most likely not physically possible on the Epic via firmware update, but would be amazing if it was!
I find it so great that Red pays attention to threads like these, so glad I invested in such an awesome company.
I would pay around $10k-12k for an upgrade board to my Dragon that would do 1000fps-1500fps burst for like 60 seconds at a time?
Buffer to some Giant Ram Disk and then write out Redcode Raw to my mini mag 512s
The slow motion is the feature I appreciate the most (resolution and raw too of course). It makes it possible for me to film a LOT of things that would never be possible otherwise.
I can film macro shots of details in nature, in full speed wind would move leaves etc far too much. It also helps me to hand held movements that would be too shaky otherwise.
I often find myself using 260fps but then I'm sacrificing the image quality of the shots at 2K resolution. Otherwise I often stay at 96fps where I get full resolution.
Being able to use 300fps in 4-5k would make a huge difference for us, even if its only for a burst of a few seconds. Right now I worry that our 2k shots will not make the image justice being projected in a cinema but its just a "sacrifice" we have to take now.
Of course going into higher slow motion will open up doors that are closed now. I found that 200-300fps is not quite enough for very fast action elements.
Some ideas
- a burst mode that enables higher resolution loaded into the RAM for as many seconds as possible would be super useful, even if its only for 2-5 seconds this would make a BIG difference for me. This would mean that 80% of our slow motion shots could be captured suitable for cinema.
- a hardware upgrade of the camera similar to the way you upgrade Dragon. Even if we "only" get 50% more or 100% more frame rate this will still make a huge difference.
- a module that gives you higher speed. Maybe with an extra cpu and an 3 extra ssd. This way you get both faster write speed and faster processing power.
- a new camera with higher frame rate. Great, but of course more expensive. I think we would sell our Epic and get this new Dragon Speed monster instead, or hmm 2 maybe for 3D.
Many talk about renting of for example Phantom being a good option. I think that is true for many cinema productions but myself I often spend much time capturing the perfect shots during a longer period of time. For example a few weeks just filming waterfalls or birds or fire. Then renting is simply to expensive ruling it out for us. For that reason we buy our cameras instead and that is why Red is perfect since you give fantastic image quality and great slow motion.
Best wishes!
/Andreas
300-500 gps in 4K would already be awesome! I don't like To shoot in 2K , Butter i have To for The 240 or 300 fps! Shots.
It looks so far pretty clear to me, nearly no one is against it, it seems a question of motivation or money. Motivation is a given here anyway, money is the key. (No surprise here ;o)
As a standard update seems to be $9,500 these days -- when would people pull the trigger to order: If $9.500 results in X fps (e.g., 300, 500, 700 etc) @6K
haha, jarred... now you guys have to make this camera in time for fist of dawns II
We are in the field trying to finish a Natural history feature film. If it was not for 5K and lower format higher speeds we would have far less subjects and characteristic wildlife to show as something new! Time lapse and high speed show the audience something their eye do not register and is story telling! Any camera technique upgrade means new ways of selling the story. If it was not for cameras like Red One, Epic and Dragon, I would not be able to risk shooting something already out as a film! Nature shows us so much more when we take time to look longer! Working with Condor biologists, we filmed originally Red one 2K 96 FPS, of the birds soaring! Now 5K 96FPS! This speed showed the biologists something they thought but never observed! The primary feathers acting independently like fingers made the slight adjustments to wind and air pockets alone. So subtle was the movement....it took a higher speed to be able to observe this behavior!
What could we learn at 2000fps and be able to communicate as story tellers to share with an audience if we embrace new higher frame rates and other inventions!
At the risk of being a "Fan BROTHER", no other camera has been giving us the variables to re shoot nature and wildlife as Red has! Keep inventing by All means, thank you!
Kennan & Karen Ward
As for the red epic camera, any speed improvement would be nice.
I don't know in what mesure the burst mode would even be possible.. but that would be magic if it could. A 5 or 7 sec burst mode with up to 300 fps would be already very interesting to me.
Another solution would be to be able to shot a 4k 150 fps, a 3k 200 FPS or even a 2k 300 but at full sensor size.. maximizing the lens definition at lower resolution on one side is as important as maximizing the pixel number at the other.That would be great to me for the next one or two years,
even without burst mode. Never understood why this hasn't been done yet. Basically you would get a 2kmode but with up to 300 fps and a Alexa type of image. Or maybe its impossible, i don't know.
Its a religious thing, best not to ask....
$50K is a bit steep for some owners to buy, but I would definitely rent a DRAGON with high speed specs like this for shoots that need it (and probably for ones that don't too - slomo is addictive!)
keep in mind the competition is $125k starting. SO $50k is very affordable in terms of high speed... Rental would be much cheaper as well. Besides, what's the point of everyone owning a 1000fps camera? haha
If there was a way to even do 2k at 1,000 fps in a 5 second burst it would be amazing! I imagine the FS700 has a sensor able to handle its burst mode. I feel like the Red Dragon might have most of the hardware capability to do this and more but I don't know...Would be bad ass :)
I definitely think a high speed 1,000 fps 4-6k resolution Dragon would sell like hot cakes
