David Battistella
- Apr 30, 2007
Look.
If you have downloaded and used Clipfinder for free you know that it is one of the best R3D management tools out there.
Hans is a software developer who has limited resources to work on CLipfinder. If you have not already done so then I suggest you should go to his website here:
http://www.daun.ch/software/
and hit the donate button.
To many, this is essential software in the RED workflow. Surely you can take the time to extend kindness and support to this worthwhile endeavour. Le't show Hans that the REDUSER "community" can do their part to help support his efforts.
David
Here is a small list of what you can do with Clipfinder.
-Quickly browse, play, select and annotate clips.
-Judge image detail and sharpness at 100% magnification, even on a laptop in the field.
-Make a subselection from a large set of clips, add comments and save references to the selected clips in a small file. Reopen the file later to view and process the selected clips.
-Quickly open clips in REDAlert for changing look settings, performing one-light colour correction, etc.
-Render clips to QuickTime, DPX or TIFF files using customisable render presets.
-Trigger an Automator workflow with selected clips.
-Quickly import clips into Final Cut by dragging selected clips from Clipfinder into Final Cut.
-Replace reference files or low resolution proxies in Final Cut projects with high resolution, one-light-corrected and fully rendered clips (via XML export / import).
-Prepare a list of all clips in a Final Cut project.
-Create an annotated list of clips for printouts.
-Copy a selection of .RDC directories.
David
