Ian Laurie
- Apr 6, 2008
Final cut keeps crashing due to the RED QT plugin. What can fix this?
Okay, I figured out WHAT the issue is, but not sure why Color is doing this. I have a MacPro with two monitors hooked up to an ATI 2600. If I have both monitors plugged in, it gives me crap in the output at anything over 10bit. If I have just one monitor plugged in, all depths render correctly. I'm not sure if it's more of a Color issue, or if it's something to do with the RED plugin. I haven't had this happen with any other footage (non red), so it's got to deal with how color deals with RED footage through the plugin.
Matthew
That sounds like a GPU issue (color renders through that). There was another thread in this forum about the different pixel formats supported on the ati and nvidia cards
I'm not sure but I read somewhere it's not indicated to send to Color the effects with R3D files.Do you want an email of the Color crash report?
I'm getting lots of crashes. Seems to be tied to speed changes, redcode 42, and maybe other issues.
Footage is 4KHD. Shot on build 21.
Some sequences are redcode 36, some 42, and a couple 28.
It's strange, so will go into Color, others just crash it.
I have a bad news and a good one: the bad is the spanned r3d bug persists, the good one is the amazing clipfinder can fix it :smile:
mmm...it could be, we'll see when the new red plugin for quicktime comes out.Probably the spanned R3D but is coming from the REDCODE version and the Color plugin just handles the color process?
Spanned R3D's: what exactly is the problem? It should absolutely load clips that span multiple files properly. Please let me know *HOW* you're loading the clips that are giving you issues!
You will need to re-send from FCP, you cannot load a previously sent sequence that failed (I think Color caches which plugin / codec to load for a project, which would be why your old stuff worked Ben)
Apple have to add in the controls for that. All we do is, as Rob says, pass them the image decoded as per the settings they set.
It's the same issue there has always been. Loading spanned R3Ds works, but doing a 'send to Color' with proxies that refer to spanned R3Ds gives a freeze frame.
if I have a saved sequence already in Color using the 2.9 plugin, does this Color-caches-plugin-version thing also affect it?
I've identified the issue in the code. Will get cracking on a fix. Thanks for the info!
It should not. I think you're fine.
Someone could tell us how the new plug in perfoms?
Did you got the same results as with the lastest Red Softwares?
Good to know
I have no r3d at home yet to test it by myself
