Ross Isaacs
- Sep 7, 2009
- Port Douglas, Australia
- www.oceanplanetimages.com.au
11-16 Duclos
11-16 Duclos
I will have to disagree with you guys as I use the Gates Deep Red glass dome and when you see the actual moving pictures I can assure you there is edge to edge sharpness. I would never use acrylic. There maybe relative motion blur from movement but the images are very sharp. You can't really judge the sharpness based on degraded screen grabs posted here. I think you will find there is far less distortion using a glass dome as the way an acrylic dome is blown is such a rough process there are always going to be flat spots by the nature of the process. The refractive index stays constant at every point of the glass dome as long as the manufacturer of the housing has calculated his nodal point correctly relative to the curve of the dome and the position to the optical axis.
11-16 Duclos
I'll chime in about the 11-16 as well....used it on a shoot in Alaska and was VERY HAPPY with results. HOWEVER i also encountered significant drop-off of sharpness and detail as you move towards the outer edges of the dome. BUT that said, it really did not distract from the image...merely a remark on what i experienced. However, compared to the Arri 8r....the 8r is so much sharper....so i'd have to say it has to do a lot with the optics itself rather than just the width of the lens. $30k vs. $1500 (i can't recall what i paid)---BUT, i'm very happy with my 11-16 PL mount and it's in my bag for good.
Johnny
