Ketch Rossi
- Jan 10, 2007
- Sardinia, Italy
- www.afroditefilms.com
Nor Canon or Nikon or any other Still Cameras from any manufacturer will present and bring you anything even remotely close to what RED is and will be offering as far as "MOTION CAPTURE" goes, in any of their current Still Cameras configurations and that is IT!!! Also this will be very unlikely to change any time soon, not certain of it, but pretty positive about it
This Still cameras are making truly incredible advancements in their fields of STILL IMAGING and even so I hate how they do it, sucking you in with bits of improvement and always holding something for the next MODEL, they are still nonetheless improving their systems, and the new 1D IV is the very example of it!
Now Motion capture in this cameras is still and will continue to be a high compression process and never will get to the quality of your expectations, so don't wait for it and gain some extra sleep
If anything the TRUE disappointment as in the new 1D IV should be that they made NO effort in the shooting frame rate, other then the Burst up from 110 to 121, not impressed here at all, was surely expecting at list a 30 to 60% speed increase in the actual Frames Per Second capture, and the fact that does not even sports the same 18MP of the little 7D, now this is some Shit that you should complain about it, and not the constant talk about how they don't do a good video cause of this or that, they never will!
Scarlet and EPIC will be Motion Cameras with Still capture, which were design from start with both in MIND, and are not trying to go back inside an already existing system designed for only one purpose and now make it work for two purposes totally different in each other's needs, and this is not a small task, not a small one by a large margin.
A while back I made a Rant Thread to Canon, but it was do to my status of mind in that particular period, and now i fill a bit better
and think that Canon still is the Top Game in the 35mm Still world and with the new D IV series has again proved to be so.
RED, is however to my opinion the only true contender that can make and deliver a system in every format that will meet and surpass each and every one's expectations, as far as the handling of each body, and their fill, is a different story as you will have many that will still like and enjoy and prefer their 35mm bodies type for still capture, mostly do to the larger Thicker bodies of the Scarlet and Epic, while the MF645 world will not have this issue, as the 645 camera systems are just about the same and or bigger, other then that, I will see no reason to NOT sale out all current photographic and video gear in any size, from 2/3 to 35mm to MF 645 and 617.
There is and wil be also considerations in their capacity of High sync, high ISO, MP count (not so much but still important), and more so how their new AF lenses will handle on their respective line of products, minus the 617 off course, for still imaging, and yes even for MF645 today's current camera in this format are pushing the agenda of the AF for both their camera designs and Fast AF operation as well as their lenses.
Then again.. so much has yet to be seen
