A. Bastaki
ovf sucks ass. it makes no sense whatsoever. look through the viewfinder of any dslr/ arri 435 or any arri camera with an ovf... man I can never know when im in focus, it's frustrating.
I shot a feature film in Turkey last year and it was my first time working with the Red One.
Check it out: www.40thefilm.com
Ok, I can see that; but noone is going to take away the big monitors from the producer or directpr anymore when the decision for shooting digital has been made, right? So they will see better anyway. And the operator, even if he can see the shot going out of focus, can't change it anyway in that moment. He can just tell the Focus-Puller...
So to me, all this is rather a question of onset workflow than technical advantage.
Okay, but then it doesn't matter at all if there is an OFV or not, the focuspuller is judging the focus by other things. He just needs someone to tell him afterwards if he judged right. Normally was the operator, could be someone else now.
I was trained as a sound engineer. We always listen to the end of the recording chain so that we can judge if anything happened to the signal on the way. So that is why I am probably a bit confused and biased
IF he is operating the focus was what I was sayingI just wanted to say that you can't compare the demands of a photographer shooting stills in regard to the needs of a cinematographer. And I have seen photographers checking the images on a monitor as well. So they had to check although they had the OVF before.
Of course we are now discussing what the CinemaPHOtographer needs or might not need. And there are probably as many answers as CinemaPHOtographers so in the end it's all down to business. When Jim builds it will they come? (and pay?)
We would love to hear your thoughts.
Jim
As I said, the better EVF's get, the more the desire for an OVF will decline.
Its a pity the camera can't be put into a 'framing&focus' mode which just allows you to see through lens with the rest of the camera on sleep- to save battery!!
3. New rods/rails, base plate and handheld system.
5. New types of flash memory recording modules along with CF card modules.
Seen some pics of this one but dish us the full dirt on it please!6. New Pro I/O module.
The stuff you need on for framing and focus, ie. camera and LCD are 98% of the power draw. If you use CF, the only other things that draw power are the audio board and the rear status led - both very minimal draw.
"And there was much rejoicing"
2 or 4 XLRs? My vote would be 2, since I know I'd never need four and I'd like the I/O module to be cheaper.
I vote for further EVF development to take all the advantages of OVF away except the battery drain which I guess you just can't avoid.
Michael, I think even if this wasn't part of what Tim envisaged is that this could work with an SLR style OVF which wouldn't require powerup of the camera to work.
If RED combined a 1080p EVF with very high-quality downsampled 1080p output
Michael, I think even if this wasn't part of what Tim envisaged is that this could work with an SLR style OVF which wouldn't require p guessI owerup of the camera to work.
You know, a lot of these arguments for not doing an OVF would make sense if the only issue came down to focus v. imaging data (focus better judged on the OVF and data displays available on the EVF). But the one point neglected is judging the image itself. The lighting. Contrast and color.We all know that these are very inaccurate on the current RED One EVF and both LCDs. The brightness, contrast, saturation, hue, etc. cannot b judged even close to accurately. The EVF and the LCDs completey disagree with each other. And due to eher a quick debayer or downrezzing or combination, sometimes we get craz shifts in green/magenta or other oddball artifacts which are not recorded in the final image. So shooting with the electronic options can sometimes be a bit of a fog. I like to check my lighting through the optical viewfinder of the camera so that I take everything out of my view except what's in my image, and I'm seeing how the lens is interacting with it as well. Even the best operators will let the DP take a look without a grudge so that the DP can check the lighting. It's part of the way we work, or at least how I do. RED's monitoring is an approximation at best, and one has to take a frame into a post environment with a proper debayer and a decent monitor to see what's really there. That is insanely time-consuming on set for shot by hot work. Far quicker and more interactive to do it "through the lens." When I'm looking at the actress and wish to adjust the hairlight on its dimmer for just the right definition, it's a lot simpler to look through the eyepiece and call "woof" to the gaffer when it is dimmed to just the right level than to try it a few ways and then take a clip into FCP just to figure it out. No way that is happening on a real shoot.
And yes, we do say "woof" when something is set at exactly the right place.
