Very encouraging. What filter did you have on the last stage?
IR+ND 0.9/1.2
I wonder if an MB-20 would also clear it on the wide end using a solid NB or IR on the last stage.
No problem as long as they are at least 4x5.65.
I am also concerned with the use of 4 x 5.6 grads on the first stage and not having enough room to adjust their line on the sky enough.
Didn't test 4" filters. I suggest you use 5.65 x 5.65 grads in the MB-20 anyway. They should work no problem.
