RELEASED: Beta Build 20 Firmware (v20.1.2)
Stuart English
Red Team
Irvine, Ca
The latest version of RED ONE beta firmware (Build 20 - v20.1.2) has been released on www.red.com/support .
Significant changes since Build 20 v20.0.2 (Beta firmware release):
* Modified False Color meters for RAW, REC709 and REDspace views
* Modified Zebra 1 and 2 defaults
* Modified microphone level default
* Corrected Look Around area on HD-SDI and HDMI for 4K / 3K / 2K ANA mode
* Changed USER KEY 4 to VIEW RAW, changed USER KEY 5 to COLOR.
The modified False Color overlay provides the following information:
Purple
Minimum Exposure
Teal
3 stops under reference
Green
Reference Exposure for 18% Grey Card
Pink
Reference Exposure for Caucasian Skin
Straw
2 stops over reference
Yellow
2/3 stop under maximum exposure
Orange
1/3 stop under maximum exposure
Red Maximum Exposure
Note: This firmware version completes feature set development for Build 20.
Exposure assistance meter disclaimer
The above firmware version has made adjustments to the calibration of the Histogram, Sensor RAW meter and False Color Overlays.
Accuracy is improved, however it is recommended that users conduct appropriate exposure tests before use on a commercial production.
Thank you Stuart. As a test pilot I have been testing this build for this past week
and it is GREAT. The false color, RAW histogram and your light meter all sync. Thanks again
Can you please post a (quickly made) reference bar similar to this one I copied from release B17 manual so we can easily visualize how it changed...
Can't wait for a release Build 20 so it can be used on real (paid) work. Right now I keep on using B17 but do all the conversions using new color science, making a new White Balance and grading with latest desktop apps... it works great but would simplify once the camera is running B20.
Thanks for all the amazing tools
Mikael
Thank you Stuart.
Does this release address any of the bugs in the Master/Slave feature.
I'm still experiencing frequent lockups in the slave camera.
Thanks!
Eli
False Colors
False Colors
Sure
The green and pink bars provide quick exposure assistance for 18% reflectance grey and skin tone.
Teal represents areas of the image 3 stops under 18% reference grey, and straw areas of the image 2 stops over 18% grey.
Purple indicates minimum exposure, yellow, orange, red represent 2/3 of a stop under, 1/3 of a stop under, and maximum exposure.
If operating at IS0 320 and viewing REC709 on an HD-SDI monitor, Green is equivalent to IRE 44-47 and Pink is equivalent to IRE 60-63.
Thanks much for the quick reply.
I keep a printed copy of that chart taped on the camera body as a reference when working with DOP who never shot with the RED one, it helps a lot in the first days so they can expose properly. The new false colors look like they will be even more useful as they represent smaller value ranges. Really is like a multi colored zebra of the 21st century.
The only thing they had trouble with was the several teal colors representing darkish areas which were visually lighter than the gray above it, once they understood that, all was good.
Is it also now representing RAW exposure more accurately ?
Mikael
Sure
The green and pink bars provide quick exposure setup for 18% reflectance grey and skin tone.
Teal represents areas of the image 3 stops under 18% reference grey, and straw bar areas of the image 2 stops over 18% grey.
Purple indicates minimum exposure, yellow, orange represent 2/3 of a stop under, 1/3 of a stop under, and maximum exposure.
Will give it a spin tomorrow on a short movie I'm DP'ing.
Looks like another significant upgrade! To think, just two days ago I was explaining the old version in detail to a cameraman for a job next week.... now I'll have to explain it all over again (but that's a good thing!).
Love the recent focus on image development and improvements! Keep it coming....
Cheers from Tokyo!
Paul
So does Skin tones fall 1 stop above 18% now? Or is it still + .3 Stop?
Zebras on Build 20
Zebras on Build 20
A note on Zebra operation in this version 20.1.2 of Build 20.
As you probably recall Zebra settings can be adjusted by the user and are remembered over power cycles.
Zebra settings are also stored as part of a USER PREFERENCES file.
In this Build the defaults were adjusted so that -
a) They are both enabled - so that's what the diagonal lines in the image are.
b) Shadow Zebra falls on the Purple false color bar
c) Highlight Zebra falls on the Yellow / Orange / Red false color bars.
Again, these are just default values, these settings can be adjusted to taste.
And you can turn them off if you wish - your choice.
Ok folks, here's a useful iPhone sized reference card you can copy to your Photos folder to carry around on set with you. Great way of showing new DPs what all the colours mean.
HTH
Paul
And just for those completists who want to see how accurate (or not) their iPhone's colour is.... :laugh:
Cheers!
Paul
For some reason I cannot change the user settings now on the back three user menu buttons. Side buttons work fine, but the back three are set at ISO, Color Temp and Shutter. Any clues for the clueless?
This concerns me are these still user selectable? i like to have 1 as raw 2 as color.
Stuart was generous enough a couple weeks back to help us out with this little handout we printed for REDucation last week.
The general information is for people relatively new to the RED, but the new false color chart with the ISO320 / REC709 IRE values may come in handy:
http://www.keslowcamera.com/Keslow B20 Handout.pdf
