David Rasberry
- Aug 20, 2008
Maybe the new Epics will make this moot.
Carsten, I believe you used the camera before it had an OLPF in it.
Ah. It looked like there was one but it looked to be not very strong.
How strong or weak is the new one?
The point is that we have a great 4K camera, why can't it shoot 2K with the expected drop in resolution and the expected effects from going to a wider lens and maybe a bit more open iris but still give us a usable picture with subjects at about 15'?
EX1, EX3, F900, HPX3000, etc.. none of them deliver a full 1920x1080 measured resolution.
Isn't it a simple matter of 2K photosites actually being equivalent to 1.6k pixels? Ergo, you have to uprez to get the 2K (1.6k) to fit in a 1920x1080 window, or 2048 x whatever window, for the DI. The 4K footage, more like 3.2K is more than enough information to downrez to the same 2K frame. The uprezzed "2k" originated footage will have to be soft compared to the downrezzed 4k footage.
If you were downrezzing both of them to a 720P finish, perhaps they would be more comparable. But the uprez/downrez matching seems to be where the problems lies. Correct me if I'm wrong.
"A debayered 2k image [WITH THOSE SETTINGS] is still 2048x1152 (16:9) pixels, each fully defined with RGB color data. The optical resolution as reproduced by a test chart will be lower."
Then, it's lower. It's been scaled up by the algorithm.
You can have Photoshop turn a 300x200 pixel image into a 3,000 x 2,000 pixel image. So what?
And yes, Sanjin, your test is a bit soft.
Wow, this thread has seen some action. It has been a long week for me already, but I was able to shoot some more quick and dirty tests to see what is going on here. I haven't had a chance to critically review these yet, but if you want to download the TIFF's you can do so here:
2k Soft Focus Test: (301MB)
http://www.ryanewalters.com/downloads/Res-TIFFS.zip
the 2K crop from 4K and the 2K shot look essentially identical.
