David Rasberry
- Aug 20, 2008
I wonder if the Vantage rehoused Leica glass would cover FF35.
I think that's a slight oversimplification. In ample light, one can get the advantages of the larger sensor without any change in DOF by stopping down.
IMHO the switch to digital capture for most episodic TV is simply a matter of time. The RedOne will be chosen by many of them. For RED to garner the lion's share of that market greater sensitivity and/or better S/N ratio (kinda the same thing in practice) is the key....... With another stop of useable sensitivity it would own the episodic market. Just my 2 cents.
Sorry for not giving the warning, guys. Long story.
I'm just bummed because my DVR somehow forgot to record the show!![]()
Considering that much high end television production is currently lit to about a 2.8 on a recording medium that's at least one stop faster than a Red (i.e., 500 speed film, for the most part), I consider it unlikely that cameramen would choose to shoot a Red at, say, 1.7 or less, which for what you're suggesting would be necessary if the effective shooting speed of the new sensor designs is not significantly faster than the current model.
And even if it's technically possible, the choice of a 2.8 stop - or, in some cases, a 2.8/4 split - is based as much on what's generally considered the sweet spot of current lenses than the need to use fewer lighting units.
Of course, if the new designs yield a sensitivity that's closer to 500ASA than the current 250-350 (depending on who's rating it), that would be a different story and a potentially good reason to adopt the newer technology.
If you're always in low light, then "add more light" is not a useful option, so the larger FF35 scarlet sensor will only equal the S35 scarlet and not surpass it. Shoot exteriors, though, is different, as one can often use less ND to get more light, so FF35 would surpass it.
If you're already pushing your puller to the limit with your existing DOF, and you can't add more light, then FF35 can only equal your existing noise+DOF. If you accept thinner DOF or add more light, then you can get less noise for the same DOF, but that's not going to happen in every situation.
this is quite a statement.. that cam was a dream became true till red1.. 7 or 8 years of total dominance.. a legend.. how dare you?the F900 with its 2/3" chips is essentially a news camera on steroids
Let's speak practically here -- ....
We have no idea at this point what the sensitivity is of the EPIC nor how it looks at higher ASA ratings, so we can't really know for sure whether this depth of field issue will be a problem or not.
Moco on the RED has also become another area of considerable adoption
An interesting note on how the show was graded: you'll see a lot of clipped highlights and crushed shadows. Those of you who watch the show will recognize the look, but to those viewing it with a strictly technical eye... that's all in the grade.
I'll post some technical details about how we shot the show [etc.] when I get permission.
Let's speak practically here...
Everything said today is based on either current or past experience
I'm glad you said this.
I also wished there was a way to see this without it going through the par-for-the-course MPEG2 stuffed in as little bitrate as they can manage pipeline that even the HD sat channels force...
[*] RED ONE in 2K windowed, 250 ISO, 25mm f/2.8: aperture is 9mm
[*] RED ONE in 4K mode, 500 ISO, 50mm f/5.6: aperture is 9mm
[*] RED FOO (see above), 1250 ISO, 80mm f/9: aperture is 9mm.
