Rami Mustakim
- Jan 10, 2008
- Age
- 51
- Paris, FRANCE
- www.monsieurmonsieur.fr
Ok everyone, I’ll try to expose here what I understand about gamma issues in Quicktime. Don’t know if what I do is correct so please feel free to tell me if you think I’m wrong.
1- Everybody seems to agree that when you work on Mac you should calibrate your monitor and set gamma to 2.2.
2- There’s another gamma issue. When you export your Red footage (In RedAlert for example from R3D to Apple ProRes 422 HQ). What you grade in RedAlert and looks good to your eyes becomes suddenly completely washed out in Quicktime.
Solution seems to be that if you have a Mac and have FCP2, then check the QT pref Color Compatibility so you can see what it should look like.
It works fine but then it’s only a way to see it right on your Mac. Your file will still look washed out on a PC or a Mac without FCP2…
3- I read a lot about this. I’ve tried many things. And I’ve found that:
- In RedAlert when you export your R3D file to a Quicktime File with QT codec set to “None” then you get a file with no gamma issue! It means that your file looks the same whatever you check the QT pref Color Compatibility or not. Gamma won’t change. Best of all you can export your file to whatever you want (Apple ProRes 422 HQ for example) and your file will still look good. Gamma won’t change even if you you check the QT pref Color Compatibility or not.
Question is why can’t we do it directly from RedAlert?
- If you exported your R3D file to a Quicktime File and have this Gamma problem you still can get rid of that issue. How? Well, you’ll have to export your file (command E).
Then click Options… Check Settings and Size so that your file remains the same.
Click on Filter > Settings > ColorSync
Go to “Source Profile” and select your Calibrated Monitor’s name (for example “Display Monitor Calibrated”) which Gamma setting is 2.2.
Then go to “Destination Profile” and select your Native Monitor’s name (for example “Display Monitor”) which Gamma setting is 1.8.
Now you can export your file.
What you’ll get is a file (same size and settings) with no Gamma issue. Gamma won’t change even if you you check the QT pref Color Compatibility or not. Your File will look good as well on your Mac or your PC.
That’s it.
Rami
P.S: Sorry for my bad English I’m French.
Once you’ve done that, the monitor of your Mac has the same gamma setting as a PC so you can safely grade your Red footage knowing that it’ll look the same on a PC as it does on your Mac. But…Hey all, Just a reminder (in the mac world) to set your monitors to 2.2 gamma.
That’s it.
Rami
