- Admin
- #1
Brent Carter
REDUSER.NET
The latest version of RED ONE beta firmware (v3.4.1) has been released on www.red.com/support .
SUMMARY: RAW exposure meter, embedded audio and time code in HD-SDI outputs, 4K HD recording mode (3840×2160 pixels), support for RED 16GB CF cards and RED-RAM 64GB flash drive, enhanced Timecode and Genlock functionality, USER 5 Key (located on RED-LCD), GPI trigger functions – Pre-Record, Shut Down, Play Clip, Next Clip, USER KEY functions – Ramp, Timelapse, Record, ability to disable GUI elements, CLEAR LOOK function, camera firmware support for RED lens S4/i interface, user programmable Safe Action / Title, 1:1 native sensor image magnify, User Preference file, Battery Cycle count.
Significant changes since Build 17 v.3.3.9
* Completed optimization for RED 16GB CF cards.
* Addition of embedded time code in HD-SDI outputs.
* Addition of CROSS JAM (creation of 23.98 fps from 29.97 timecode)
* Addition of CROSS GEN (creation of 29.97 fps from 23.98 timecode)
* Added USER KEY function – Record
* Changed method of writing camera LOG file – access via SETUP menu.
* Changed location of PRE-RECORD – access via MEDIA menu.
* Selection of lens Distance data reporting in Feet or Meters
* Addition of Audio LINE input gain control 0dB / 10 dB.
* FALSE COLOR exposure meter tracks VIEW selection – REC709 / REDspace
* Corrected operation of Shutter PHASE control.
* Added USER programmable Safe Action / Title guides.
* Changed MAGNIFY to display 1:1 native sensor resolution.
* Added selection to playback clips using CLIP or CAMERA LOOK values.
* Added USER PREFERENCE file.
Thanks, BC
Thanks, BC
