Peter Majtan
- Feb 29, 2008
- Tokyo, Japan
- www.petermajtan.com
Jim, here is my one peso of what I personally would like to see on the DSMC:
* Interchangeable lens mount ala "BirgerIMS"
- most (if not all) pro photographers invest a ton into their lenses and keep them for a very long time - unlike the body. You should offer an upgrade path where they are able to buy the RED DSMC body and use their existing lenses... (hence IMS)
- Nikon & Canon mounts are an absolute minimum, but they must allow for full electronic control of Iris, AF, TTL metering, OIS and other features currently available on the most commonly used lenses directly on the camera body... (similar to Briger)
* F35mm sensor (Full Frame 35mm Still Format)
- going any bigger and most current 35mm DSLR owners won't be interested due to the lack of compatibility for their existing lenses...
- if You want to go bigger (such as medium or large format), please make it either a separate model, or in a form of interchangeable sensor cartridge. This way one could "stick-in" medium format sensor with appropriate lens mount and use his camera for such a purpose. Then swap the sensor for 35mm and relevant lens mount and use it for that purpose... This would be indeed revolutionary. User can chose huge image size/resolution with lower frame rate (or even single still only), or smaller size/resolution with higher frame rate as required...
* HDRI sensor
- the DR has to be out of this world
- automatic multiple exposure mode that combines the data to single HDRI RAW image (no need to do this manually in post), similar to ARRISCAN
- "Auto-stretch" HDRI mode - to stretch the data between absolute black & absolute white to maximize the use of the available bit depth. User selectable of course, this function maximize the RAW data quality with maybe a meta-tag stating the original darkest & brightest points values as reference for post...
* Detachable control panel ala EPIC
- this will allow for wireless remote control of the camera for wildlife or any other situations requiring hands off the camera...
- ideally the panel should feature the LCD image with "Live View" transmitted from the body so we can see what we are about to capture...
* WiFi data transmission
- wireless transmission of the RAW image data for remote data capturing / backup
- allow full control from WiFi equipped PC/Mac with image capture directly within the SW (ala Canon)
* Compatibility with internal/external large capacity recording media
- to allow for long-term recordings, such as timelapse, video, etc...
- ideally it should feature at least 256GB internal SSD drive...
* Weather-sealed, including lens mount
- should be able to withstand direct exposure to rain and brief submersion in a water...
- definitely dust-proof with self-cleaning sensor...
* Weapons-grade aluminum/magnesium/titanium construction
- I should be able to defend myself with the camera against a charging rhino and have to worry more about hurting the rhino then damaging the camera...
* Ergonomical
- I don't have to elaborate here...
* Not too small, or light
- robust solid construction that aids with stability
These are just a few things that come from top of my head...
Of course I don't expect any feedback...
Peter
EDIT-01: As Shawn correctly pointed out - Instant recording from cold power-on (ala current DSLR's...). Basicaly be able to take a picture within 5 sec from a cold start...
* HDRI sensor
* Ergonomical
