- Moderator
- #21
Evin Grant
Moderator
- Dec 28, 2006
- SoCal
- www.evingrantdp.com
I am looking at the lens hoods right now, and I think I'll go for the most part with the 72mm (considering also 82mm).
I want them all to have the same front diameter to easily fit it on the matte box. Longer hood will also help me with the 50mm which has the most problems to fit in the MM
Found it all at B&H
Here is the hood link:
http://www.bhphotovideo.com/c/product/357648-REG/Kalt_NPMLH72_72mm_Metal_Lens_Hood.html
What you think about the hood?
Has anybody found a better one?
77mm step up rings have 80mm OD just like Zeiss Standard and Super Speed lenses. That is one way to make them fit universally with a production mattebox.
There is clearly a difference in the bokeh. The regular Nikons have a hexagonal bokeh, whereas the Zeiss have a circular, smoother looking bokeh. The mechanics are also very different. Picture to picture, a casual viewer wouldn't be able to tell the difference.
Yes, the older manual focus Nikkors often had seven bladed apertures. Most modern Nikkors and the better MF pro Nikkors have a nine bladed aperture like the ZFs. For instance the 50mm 1.4 Nikkor has 7 the 1.2 & NOCT have 9.
This list will tell you what Nikkors have what blade configurations as well as other interesting info.
http://www.photosynthesis.co.nz/nikon/serialno.html#85
