Meryem Ersoz
I think his point was that the Birger is going to be so revolutionary that it kills off the value of PL mounts...I doubt that will be the case, but it will actually be amazing to have a broader range of relatively inexpensive lens choices, with complete coverage from 14mm - 600mm (even 800mm if the Sigma knockoff lenses work) in fast lenses.
Since it appears that the mount is not that simple to swap out (yet), I doubt that PL will go the way of the dodo or suddenly lose half its value...and you'll be able to sell used PL lenses for less of a hit than you might take on the Nikon/cheap lens combo. You have to put up a lot more initially, but you'll get most of it back.
