Jannard
Red Leader
- Dec 28, 2006
We have done quite a bit of work on the DSP in the last few days and need to report a few things.
1. We have found the bug that was causing a slight resolution dip at lower ISOs. There is now no difference.
2. The absolute best ISO (closest to linear) is ISO 320. We still stand by our range of ISO 320-500 being the most practical choices for "standard".
3. As ISOs increase or decrease from 320, there is a curve adjustment to make them work. The further away from ISO 320 in either direction, the more the curve adjustment there is and the more "penalty" you pay. Most recognize that information is "pushed" to accommodate higher ISOs, the converse is true with lower ISOs (mercifully, resolution is not one of them). While ISO 125 will look great from a noise standpoint, it will not have the the same range as ISO 320 due to the "pulled" curves. Do not treat RED like your film experience... lower ISO is better. You have ISO 320 "film" in RED.
4. While a comparison of RED in a standard situation (like the charts I shot) has proven that it is extremely difficult to tell the difference from the best DSLRs, in very highly detailed, high contrast scenes (like full frame trees and grass in the noon sun), RED will drop some by comparison. The reason is the data rate. At that point you are comparing compression and not resolution. RED shoots a typical 1.5MB file with REDCODE 36 (which is why you can record 4K at 24fps to a Compact Flash card). That is compared to an 11.6MB file from the Canon 1D MKIII. While RED looks incredible in these situations for motion, you will see a difference compared to a still DSLR. It just makes "science sense".
As usual, "we calls them likes we sees them".
Jim
Jim
