Anders Holck
- Dec 28, 2006
May I suggest a video of the different EVF adjustments? Just quick peek...
The other issue with the die cast... finish. The material used for diecasting aluminum isn't really 100% aluminum. Its typically a casting alloy that is better suited to die cast and it releases easier from the molds etc. It will never look like anodized aluminum. So the options are limited... either take the finish as it is or complain until Jim has to bite the bullet and powder coat everything. I personally like the finish, it kinda reminds me of a gun finish of some sort.
I'd guess that the bottom plate tooling probably ran about $120K...
I am suggesting that parts must look like that because they're cast. Die cast parts have a specific finish. They typically come off the tool smooth and then you can either tumble deburr them or bead blast to get varying degrees of texture. Anodizing never looks nice on die cast parts. Personally I've done at least 10-20 die cast components in varying levels of complexity in my career... If we ever had an application that had critical finish requirements we'd powder coat them or paint them.
I have lots o ET stuff and they have done a great job. Stephen is a great guy. I plan to buy more. Although there are some things ET hasn't made or not yet at least.
I also don't think it is fair to say we are expecting Mercedes quality at Hyundai prices. It's just inconsistent. Some of the same parts are done better and worse.
This looks great! Definitely add us to your mailing list for prices and delivery times and I'll keep an eye out here too.Hi Guys:
With all this talk of accessories, what do people think of the following set up we have developed at SIM VIDEO?
1) Handle/VF support/Battery Plate: This system includes everything you need for your RED upper support. Using lightweight, but extremely durable aircraft aluminum, the handle is extremely versatile with multiple 3/8th and 1/4 threaded holes. On the viewfinder mount, there are multiple adjustments available, with positive locking features, and it comes with a 4" and an 8" extension rods that works with the standard ARRI style EL3 eyepiece leveler. The battery is mounted on a moveable system that allows with one lever to adjust the battery anywhere from flat across the top of the camera, to straight down the back of the body, and any where in between. Battery holder is set up for mounting RED, Anton Bauer and IDX battery plates.
2) Toe Piece: The toe piece works with all ARRI dovetails, and has 15mm rods with Studio and Lightweight rod spacings. Positive lock system holds camera securely on the dovetail.
3) Downconverter/Breakout Box: Converts one HDSDI to VBS (standard definition) as well as giving you access to USB, and all DIN connectors on the RED. Power comes via the 12v connector on the rear of the RED.
Anytime we have shown any of this at our shops, we get bombarded with requests.
What does everyone think?
John DeBoer
Director of Eastern Operations,
Sim Video Group of Companies
(Los Angeles, San Francisco, Vancouver, Toronto, Halifax, Beijing)
WWW.SIMVIDEO.COM
The reason for this is, because they have been sandblastedI wanted to attract the attention of RED QC to the fact that some parts of RED hardware are coming with alternative (not as shown on the RED store website) method of anodizing.
This type of anodizing is prone to scratches and greasy spots done just by touching, that is very difficult to remove. After a few month of use it will look like set of fire place tools.
Correct me if I am wrong, since I am judging looking on the good quality pictures from unpacking thread.
But if it is what I think it is, then you better call your subcontractor to stop saving on anodizing process.
Agreed. Fit and finish should be consistent. ET makes great stuff. I plan to buy most of what ET makes, but they don't make a red cradle or quickplate, or handle, etc. which is the main reason I'd still buy the production pack. If ET made all Red accessories, I'd buy them in a heartbeat.
BTW, I asked Stephen from ET about a mounting solution for the RED Drive this week, and he told to wait 'til next friday, that I won't be disappointed... I guess you won't too!
If they have a cradle I'm going to really have to think about this.
Cradle is not really needed. Best bet is to have a shoulder pad system with a dovetail on top. This way you just slide the ET/RED plate off the head dovetail and slide on your shoulder pad dovetail system.
There is a getto way of building your own. Take a flat peice of steel, drill holes in it for bolts the size of a dovetail plate and put a bunch of good quality velcro on the bottom side of that plate (use a lighter to melt up the bottom glue side of the velcro and when you stick it to the steel it will stay there forever). Then when you need to do handheld you just screw on the plate to the bottom of the dovetail. Buy or build a foamy shoulder pad that you put velcro on bottom of to stick to that steel plate.
You can also buy complete systems like this online. I am pretty sure Element is building something like this.
We have also noticed the difference in finish between various accessories.
And here is another thread about what we feel is sub-par quality on some RED Accessories
http://www.reduser.net/forum/showthread.php?t=8889&highlight=plate
There has not been any response from RED on that thread either.
I have to second finner, ET is the way to go, !
The Most Noticeable thing that this thread went on until now with 56
replies and around 2700 views and more that 6 pages without
any respond from any member of REDTEAM
WHY :innocent:
we used to see .jim. jarred. Brent ,.....most of them the do fast respond
and promp reply .with no any delay ..
whyhmy:
is it something wrong .....:blink:
are we right or wrong disscussing this ...?
