- Banned
- #641
LEON
Banned
And you are?
It's ok Leon, you are smart, cool, and patience. We, juggling with kits, budgets, and jobs, are not.
Now, basta così, prego.
Gracie mille, Friday night really makes you that nervous ?
And you are?
I bait Birger's mount ships before you have your RED in your hands ?
OK ?
I actually don't mind if I have my Birger mount in july. I have some pl mount lenses to use with my RED. The problem has been stated by many customers already. Now if Birger came on this board and gave us a bit of confidence then that would be awesome.
Though honestly Leon why do you think it is your job to try to give Birgers customers confidence?
maybe you should be as patient with peoples complaints as you are with birgers pr policies.
The cable that is plugged in goes to the camera for power and communication. The connector above it allows for a wired connection to the remote control, which if plugged in, will disable the radio. The connector below is for the accessories, such as knobs and zoom motor.
We had a break through on the collimation of back focus. We can use a known lens that most people are likely to have access to (i.e. 35-70 f/2.8), a +1 diopter lens and a test chart at 1 Meter to do the collimation. The difference in optimum focus position of the lens (in motor counts) is found between the wide and narrow focal length, both with and without the +1 diopter lens; these two signed numbers are fed into a statistical model for the lens used, and out comes a number that indicates how much to add or subtract from the shims. Because there is going to be error in the magnification of the lens and the placement of the chart, there will be error in the number. So this needs to be repeated one or two more times, until the differences aproach zero. Should be a really quick, really cheap, really accurate colimation. We need the camera back to build the statistical models for a few lenses.
We expect to have the final PCBs back tuesday of next week, and start shipping 29 February.
Very cool. Will Nikon lenses on the Canon mount (via adapter) be affected by this?
Can anyone provide feedback on the Nikon to Canon adapters?
Since the backfocus/flange focal distance will be calibrated properly for EOS, your Nikon, Contax/Yashica, M42, Leica-R, etc. will work fine. (Assuming they work fine to begin with)
I have already been using these on the current birger mount I have which is the standard industrial mount but doesn't have the RED specific lemos on it.
... and start shipping 29 February.
