- Moderator
- #1
- Apr 19, 2007
- Los Angeles
- www.phfx.com
I’ll attempt to keep this brief, but we can go very deep into the woods together discussing all things media related. I mainly want to discuss what media type RED V-Raptor uses, why, and some of the small differences in flash memory that may or may not have an impact on your decision on what to use. What I’m presenting here is based on my own R&D, testing, as well as consulting with RED, AngelBird, and even other manufacturers.
What type of Media does V-Raptor use and why?
First up. RED V-Raptor has a maximum data rate of around 800MB/s. That’s about a notable increase versus the maximum data rate of DSMC2 bodies at around 300MB/s. Because of that, particularly at higher frame rates, V-Raptor needs media that can handle that actual sustained write speed with over-provisioning.
The media type and technology RED chose for V-Raptor is Compact Flash Express Type-B. Also known as CFexpress or CFx. CFx has been around for a hot minute now, yet might be new to you. However, not all CFx is created equally and may not be ideal or compatible with V-Raptor. The performance levels that V-Raptor requires to sustain those maximum data rates are demanding. It’s rather critical to use RED Branded or RED approved media that has been fully tested and vetted. The critical features for V-Raptor is the CFx needs the media, controller, and firmware to all meet the specs required for reliable recording. RED has so far tapped Angelbird for their official media, but there are of course RED approved 3rd parties as well.
Selecting the right media for you.
There are some considerations when it comes to flash media. And this is where we get a bit technical, but I also want to provide some practical perspective here. Inside these CFx cards there can be several types of NAND flash as well as grades. RED right now is focusing on SLC and TLC driven NAND technology. These each provide an interesting balance between price, performance, and capacity. And the key word there is performance in the form of endurance. Let’s dive in.
There are actually 4 major types of flash media and I’ll attempt to summarize those differences below. SLC uses 1 bit per cell, MLC 2 bits, TLC 3 bits, and QLC 4 bits. This will have an impact on media cost, speed, endurance, and capacity for the given form factor of CFx.
Flash media is rated by PE or Program-Erase cycles, a number rating that reflects the ideal minimal cycles before the flash itself begins to wear. I’m providing general approximate minimum writes for each type of flash. And there’s a good chance it will perform beyond that spec in most cases.
Let’s take a look at Angelbird’s line-up for high speed CFx cards
AV PRO CFexpress XT MK2 330GB, 600GB, and 1.3TB are SLC mode driven
AV PRO CFexpress MK2 1TB, 2TB, and 4TB are TLC mode driven
This rings true for the RED branded media of the same capacities.
Taking a look at SLC and TCL NAND Flash for Consumer Grade Media this is often between 50,000-100,000 for SLC and 700-1,000 for TLC. But you will note I stated Consumer Grade Media. I reached out to Angelbird to get an idea of the expected performance for both SLC and TLC. First and most importantly they are using Enterprise/Industrial Grade NAND Flash and this has a big impact on reliability and longevity. Angelbird’s performance on SLC is 100,000+ PE cycles and for TLC is landing in the realm of 7,000-10,000 PE cycles.
What does this actually mean on a practical level?
Alright, you survived the tech stuff. Short and sweet, SLC cards will be lower capacity than TLC cards typically when it comes to price. And the question here is should the PE cycle difference be a concern for you if you want that higher capacity?
Consider a pretty heavy filming year for a single media card from a busy rental house or production. A nice number would be 250 days of filming with 4X full media writes and formats. An unusual and extreme workflow scenario really both in cycles and days worked in a year. This makes a nice even number of 1000 writes and formats per year. So for the RED Angelbird media TLC you would have about 7-10 years of this style of very heavy shooting ahead of you before hitting the spec PE rating. But I stress most people will be in the range of 15+ years considering most realistic scenarios are likely 10%-25% of that extreme use case. SLC is pretty much a worry-free condition all together as the PE cycles are so high, but of course smaller capacity cards. And yes, media can fail early for a variety of reasons, hopefully under warranty, but do treat your media like it’s your only child in a post apocalyptic survival film.
One last note regarding media failure. Angelbird’s cards have a feature that even when the card exceeds it’s PE cycles and can’t write data near the end of it’s cycles, you can still more than likely read off of it. This is a nice additional failsafe for motion picture recording. Several other manufacturers offer this, but not all which was a recent discovery.
Wrapping up and some tips.
Summarized perspective on all of this. If you need bigger mags for longer takes or if that fits your style of working, don’t freak out by the differences between SLC and TLC. This article in particular was inspired by the price equality versus capacity difference between the 660GB and 2TB RED CFx cards. In most situations and for most motion picture acquisition scenarios you won’t be hitting these PE cycle limits for many years.
I’ll end with some media tips. DO NOT put tape or labels on your CFx cards when inserted into the media bay. They run hotter and aren’t shielded like the previous generation Mini-Mags. You don’t want to add gunk into your camera for sure. I recommend paper tape when removing a full mag to alert that it has been rolled on. I’ve seen people be pretty hamfisted putting in the cards into the media slot. Though some of these cards do have some weather protection, as always avoid moisture near your media. CFx cases are cheap and the cards themselves usually have individual cases when you purchase them. Don’t just toss them in a camera bag, Lint and other baddies can get stuck in your pins.
