Alex Zeder
- Aug 12, 2018
https://www.red.com/download/komodo-firmware-beta
SIGNIFICANT CHANGES SINCE BUILD 1.7.3beta
- Fixed user calibration error after upgrade
- Fixed inconsistent Iris values on lens swap
- Fixed R3D timecode mismatch in camera array
- Fixed Absolute Frame Guide when values are outside the format limits
- Improved RCP2 CDL control
- Added GPO Tally Out support
- Added RF Iris Compensation
- Added Prograde 320GB/640GB support
- Added upcoming clip filename to SDI HANC while in preview
- Fixed Low Voltage warnings with BP-style batteries
- Fixed possible firmware upgrade freeze at 50%
- Fixed possible calibration failure
- Fixed incorrect color space information in SDI ancillary data
- Fixed no CDL being applied to top LCD
- Fixed 3D LUT metadata displayed in playback
- Fixed 'LCD Guides Toggle' and 'LCD Tools Toggle' user setting
- Fixed reset of absolute frameguide width/height value when disabled
- Fixed playback on Monochrome cameras
- Improved Static IP setup
- Added ELQ R3D Quality
- Added Cloud Upload capability (Frame.io and S3)
- Added Autofocus improvements
- Added accelerometer and gyro data to R3D
- Added Gio Scope
- Added enhanced Timecode behavior
- Added Timecode Out
- Added External Only Audio over SDI Improvements
- Added Sensor Sync Shift
- Added PTP Timecode Support
- Added 'Basic' Overlay Mode
- Added 'Standard' Overlay Mode
- Added Overlay Opacity
- Added Guide Pixel Dimensions in UI
- Added User assignable Low Voltage Warning over SDI
- Added RCP2 external lens data support
- Added RCP2 support for sensor time and exposure time
- Added Play/Pause indicators in Playback
- Added USB drive support for logs, presets and calibration files
- Fixed 'Forget' not clearing cached network password
- Fixed lowest Lens aperture not displayed in UI
- Fixed livestream freezing after changing format
- Fixed Playback button with button lock
