Lewis James Hart
Hey guys, just wanted to ask a Q for you Komodo owners.
Just planning a TX RX wireless focus pull setup for the Komodo.
Other than using the tiny onboard screen on the Komodo, how do you setup a wireless video system with the Komodo as it only has 1 SDI port - to send to both the monitor on camera and to the TX?
Was intending to use the portkeys BM5iii for onboard monitoring, but I assume the TX requires SDI from the Komodo for signal, using the only 1 port available?
Is there a SDI Breakout box that you can get to use both?
Thanks ahead
Lewis
Thanks ahead
Lewis
