Brent J. Craig
- Aug 31, 2007
- Toronto
- www.brentjcraig.com
I had the interesting experience this week of testing with one of the Red One prototypes. I realize it was a pre-production version, but it may be an example of what a Red One with one year's of use looks like. The major challenge was that the little joystick on the back is mostly broken. You can go up, and right, but left or down is finickey. That means no Media Menu, no Format Card, etc.
That got me thinking, the joystick is a delicate sort of piece, and it does stick out from the camera body. In normal usage, it is going to get broken, probably frequently.
Don't believe me? Look at the bottom-rear edge of any Arri or Panavision mag, or the bottom BNC connector on a 435. Cameras frequently get balanced on their ends when perfoming certain changeovers. They whack into things when they are handheld, on a steadicam or in a car interior.
So, what are we going to do on set when that little stick finally breaks off? It's quite critical to the operation of the camera. Not many shoots can afford to carry backup camera bodies.
How about a software solution:
I was impressed to learn that the flash for my Nikon DSLR has a keystroke combination where you can tell it "The silly little plastic diffuser piece has broken off". You tell it the piece is broken, and it continues to work, taking into account that it's not compensating for the diffuser any more. That is good design.
My wife's Nissan recently had a recall because of a problem with engine seals. Part of the remedy was to reprogram the onboard computer with a 'limp-home' mode where it will detect the fault and let you keep driving, but limit your speed to something that doesn't blow up the engine.
In a similar way, I suggest that Red could code an emergency keystroke combination that tells the camera we have broken the joystick, and allows us to use the other buttons to emulate its functions. Maybe the playback buttons could become up, down, right, left and select in this mode.
Either that or a very solid cover over all that stuff on the back. (I prefer the elegant software-based solution!)
Whaddya think Red gods?
