Dalibor Fencl
- Sep 24, 2007
......... Obviously, it isn't simple or we'd have it already.![]()
Not only it isn't simple, but may be quite a computing load at 60fps.
From a processing standpoint at normal 4K Redcode, the pixels are coming in anyway in an ordered fashion and compressed at, currently, up to 25fps.
Now, with scaled Raw, the same 4K pixels come in in their ordered fashion, and a semi simple matrix manipulation is performed to turn an 8x8 pixel into a 4x4. Now you have a 2K ordered pixel array that can be put through the same 2K compression that currently exists that is now running up to 80fps.
I would think that simple offset averaging would be very simple and fast. Come on--"visually lossless compression" flies and this is nothing compared to that. Maybe not the full 60fps the sensor is capable of but certainly more than 25fps.
As Brook said the moiré charactaristics of shifting the pixels may be a problem, but then again--maybe not.
If the sensor is capable of 120fps 2K Raw, but the overhead of compression brings it to down to a current max of 80fps, then a max 60fps scaled 2K Raw should get at least 40fps if if was a linear relationship of Raw FPS to compressed FPS, but I think the slower the fps the closer to real time it would be so I think it could get much higher.
...Also, remember, there are other factors limiting the 80fps of 2K such as write speed/bandwidth.
Hans,
Quick question for you, when you say shoot 50fps for 25i
would you run the 50 fps through some process to get
25i, or would you just bring your 50 fps footage into
a 25i timeline and make sure the 50 fps footage is being
scene by the editing programme as 50, so its not playing at
half speed.
Please let me know if my question is not clear, and I appreciate
any response.
Stricko
Without knowing much about the real technical issues involved, I think Thom suggestion is not practical unless the RED one has HUGE processing power to be able to analyze and integrate new pixels values from an oversampled 4K image @ 60 fps... just to be able to satisfy the CF card / RED drive bottleneck.
a more 'real life' 2K scaled image (with 35mm depth of field @ 2K "windowed" datarate) would be to use only 1/4 of the sensor data (I suppose they do a similar operation when creating an instant 2K QT proxy)...
That would still requires some processing power to be able to receive 4K@60fps and deliver 2K@60fps (and maybe it is not possible to do while keeping the RAW format etc) but it seems much more a realistic "in camera" 2K scaled model (you do loose the nice 'oversampling' from Thom model) :
There is no HD-SDI output. I suspect when more people realize that, they won't be happy.
In fact, my favorite slow-motion rate is 48 fps.
Huh? What's making the pictures on my Panasonic 8.4" monitor then?!?
That'd be windowed - the sensor maxes out at 60fps for the 35mm part of the sensor, so that's a hard limit on 2k scaled.I'm a bit confused. When we were discussing high frame rate recording some months ago Jim was very confident that 2K scaled would happen and the argument was about what fps it would max out at: 75 or 100 I seem to remember..
I think the Redraw compression that is being done in real time is much more complicated than the scaling Thom suggested, so it wouldnt need a lot of computing power at all. Maybe Thom's scaling method could work even faster if he didn't use 5 pixels for each green pixel but only 4.
This is a R&D request that I humbly bring up because I came over it in a real world situation
As Matt Uhry mentioned somewhere there is some serious need for 2K scaled. Yes there is and we badly need it.
If Graeme hasn't chimed in by now, it's because he's got something in the works--that likely involves way more math, but works 10x better and is faster than we can imagine.
All In One,
Spot on! The scalability originally promised (subject to change) in this camera was one of its best assets. 4K, 2K, 1080, 720, 480(why?) all SCALED.
Hopefully we'll be able to boot into different modes eventually...
Harry
Thom's Bayer scaling is not quite right...
