....RED has agreements in place, at least for a certain time period, that would prohibit this type of native support.....
Jim
And on a related note, there is no way to trim a Cineform RAW file without "developing" it to Cinefrom444 or 422, right? If there is, how do you do it?
A new build of NEO 4K has been created to work around the RedCine 4096 export issue. With this new build you can set your project and export resolution 4095, and internally the codec will treat the image as 4096. This way you get your full image out of RedCine (minus 1 pixel on the edge) to a 12-bit CineForm 444 MOV master. When RedCine is fixed for 4096 16-bit QT exports, the projects can be set back to the default resolution.
Improvements have also been made to the AVI 4K importer for After Effects and Premiere Pro, plus there will be a new version of Prospect 2K tomorrow that supports 4K RT playback on a 2K project timeline. We would till recommend re-wrapping the MOVs as AVIs (very fast and lossless) for Premiere Pro work, but the AE will work fines in 16-bit per channel RGBA from MOV files.
New NEO 4K 3.2.0.143 : http://www.cineform.com/downloads/NEO4Kv320b143-071119.zip
Please offer any feedback from your testing.
Thanks.
No worries there Jim, we're only interested in transcoding, nothing else was being implied. Transcoding everyone's camera format to CineForm
Let me make sure I have this straight: I set my REDCINE project to 4095 and export at 4095, and Neo4K will automatically add an extra line to the edge, and then I setup a PREMIERE project at full 4096, for my "4095" wide file? (Or more likely a 2K project)
It opened in FCP for me, but not in Color or Nuke. I may have done something wrong though.
i'ts just an AVI codec like the rest. can you open others in Nuke? it works in Fusion...
