David Mullen ASC
Moderator
There's no getting around the need for the colorist for the final color-correction session so you might as well assume it will be a positive collaboration rather than worry about somehow working around the colorist. The thing to keep in mind is that there is still a lot benefit in delivering something that comes close to the final look, as much as is practical, because (1) the old rule "garbage in, garbage out" still is true, the best shots in the original footage generally come out the best at the end of color-correction, and (2) you will have only a set amount of time budgeted for color-correction so the easier the footage corrects, the better.
You just have to understand the complexity of the coloring that you are planning on using. Playing with chroma levels, gamma, black levels, or overall primaries is standard stuff, but perhaps you've designed a look that requires lots of windows, keying, or tracking objects, or variable diffusion effects added in post, or even some paint or composite work, now you are adding to the time needed and the complexity of the work.
I'm about to shoot a small period film and the general look is slightly shifted from normal - a bit of desaturation, deeper blacks, and general warmth. The warmth I'm doing in camera with gels or color temp settings, the rest is a simple deviation from a normal look that shouldn't be too hard to achieve. I just have to make sure that look is in the dailies so the offline cut has it, otherwise everyone in post may get used to seeing a normal image.
