Thomas Pierrepont
Thanks for the share!
Yea its hard to judge on a showroom floor. Always best to judge once its been through the paces on a set. So this to me was invaluable. Freefly are some cool ass people. Thats all I know.
Hearing you say "I wouldn't rent it out" makes me wonder if it'll ever be a "rentable" item in the rental houses.
All that wiring, points of connection, powering...I can definitely hear clients calling back asking to trouble shoot the issue.
As for battery, when can we get a hold of some solar panel battery set-ups =)
Another question , whats the longest lens that you would be comfortable using on the movie?
Wow that is impressive shooting with a 100mm.
Nothing to do with the Movi, in this next question.
Which system was dropping first? the REDrock or the teredek bolt?
Is this the limitation of a 2.4 GHz ISM band?
It's been my experience that the Bolt doesn't go through walls, and the Parralinx does.
Domenic, thanks for this info.
Couple of questions:
What was the average length of up-time between a given battery changeover?
Did you develop a changeover schedule to maximise up-time?
Was the MōVI battery powering the Epic?
Are there any 'majestic mode' shots in this video?
Freefly say the production model will be more rigid and wider (now fits a side-handle on the Epic) and carry slightly more - 12 pounds up from 10.
Cheers
Jake, that is just plain untrue. The Paralinx Arrow and Teradek Bolt use a very similar chipset, if not the same. We run into the same RF problems, just like the others in the market.
Also want to add that Bolt operates over 5GHz, not 2.4GHz.
