Andy White
George, what method are you using to change the menus as you don't have a touch (redmote or sidehandle?).
It sounds like you are confused about how to operate the monitor control menu. Are you expecting the monitor control menu to have HDMI already selected when you open it? When you say itʻs "stuck on LCD" do you mean thatʻs the option that is selected in the list when you enter monitor control? If so, thatʻs normal, LCD is just the first option in the list. Once you change that menu selection to HDMI, then you change the settings for your display resolution and refresh rate.
I realize it is already defaulted to "Brain LCD", so I change it to "Brain HDMI", then push the menu button to get out of it. When I go back, it's on "Brain LCD" AGAIN. That's all I know.
Ok, so thatʻs exactly what should happen. The menu defaults to LCD the first time you open the menu as well as the next, so donʻt worry about that part. The only concern you have is choosing HDMI or SDI from the drop down and manipulating the settings shown. It sounds like youʻre expecting the menu to have HDMI selected when you first open it, but it wonʻt, and that doesnʻt matter. Youʻre not activating HDMI when you select it, the HDMI signal is always active. Does that help?
Also, have you tried another HDMI monitor?
Cool, sounds like youʻre getting there. I went through this a bit as well with earlier builds, it was even less straight forward then. What worked for me was to get the monitor set up with a known HDMI input, say DVD player. Once you see the DVD picture, you know the monitor and cable path is setup correctly. Then, take that HDMI straight off the DVD player and plug it into the camera. If the monitor doesnʻt show a picture from the brain, you need to set up the HDMI menu options differently.
OK, I did just get it to show up on a different monitor. But, the image is VERY noisy, with pixels flying all over the place and the edges of the subject showing up with all kind of colors around them. And, now that that is working, I can no longer see the image in the Red EVF.
We MUST be able to see images in BOTH ways, and at the SAME TIME.
Any more suggestions?
Maybe you have mix matched settings. i.e., one menu is set on 720 on the other on 1080?
WHAT ??
How can I have two separate settings at the same time.
This is VERY, VERY confusing! I'm on the verge of giving up. FI
Sorry George, I meant maybe you have 720 selected on the monitor and 1080 selected on the camera, or vice versa....
No, that's not the case, but thanks anyway Jeff.
I think I need to take a break, like Patrick suggested, and get away from it until maybe tomorrow. I just can't get it to work, and it's better to step back, than hurl it out the window like I'm now on the verge of doing.
Thanks.
George I will also suggest you get a touch LCD whenever you can afford it. It's a big bag of hurt without it IMHO. There are so many shortcuts available on the screen that it saves so much time clicking and scrolling on the sidehandle.
Yeah. The requirement of the Touch LCD is probably the biggest misconception I've seen from those buying the camera.
