Stephane Marino
- Jan 22, 2012
- Nice, France
- www.stephanemarino.com
Thank you Eric !
Thank you Eric !
From what I saw streamed today, they have a setup at the booth with the mount. The camera is pointed at a bunch of rolling-shutter-aggrivating objects, including a strobe. Obviously I couldn't see the actual effects, being a lower-res stream and all, but everyone seemed sufficiently impressed with the on/off demonstration.Also wondering how is handles strobes.
I looked at the motion mount today. The rolling shutter effect from flashes and strobes appeared to be gone. ND worked well. The skew effect was still present. Skew was never as much of an issue with me as flash but for some people it may be important to know. The impression I got was that they were still working on things. That's what I observed.
Now that's not good. I have a mate who used this, loved it, and was about to place an order.
I love what RED have done with this tech, building it into a mount; very clever. But I'm not wildly enthusiastic IF they're involved in this move by Tessive; that would mean they've also shut off the tech from everyone else who wanted it... we don't all shoot RED all the time, and now it appears we've had one tool removed from our toolbox. A backwards step.
Do folks see where I'm coming from?
Mike
Mike
heh heh. Funny stuff. I actually first saw this (similar) technology in a welding mask way back when we first stated. The mask automatically went dark when it sensed light by a low voltage current and a light sensor.. The light bulb literally went off and we have been searching for a solution ever since.. and finally found it.
Perhaps this has been answered, but I am wondering what are the intrinsic limitations of using the "Red Motion Mount"? Other than a 1.3 stop loss of light, what are the other limitations involving shutter and framerate that will be particular to this mount?
These are all assumptions based on the filter being similar to the Tessive filter:
1. You will still get shutter skew if you want 360 degree shutter. EG the filter needs to be completely black for a chunk of time (depending on sensor read-reset). This chunk of time may need to be quite a large proportion of the frame when you start getting to high fps.
2. It may (I'm not sure) act as a permanent polarizing filter. Polarizing filters aren't always desirable (affects skies when panning, affects the specular vs diffuse vs subsurface reflections of the human face)
3. If it's like the Tessive filter, it filters IR. Of course, 99% of the time you want IR filtered out, so that's good.
Bruce Allen
www.boacinema.com
