Greg Cheng
Active member
- Mar 8, 2013
There is a special lock & unlock button at the base of the bracket. It's shown in the Liang vs Proline test that was done.
Greg I believe you are referring to the auto lock feature for the docking of the sled. The pin I am referring to is usually on the side of the bracket to hang the arm on the side of the bracket. In the video The arm was just hung from the reverse end of the bracket where you would set the rig to balancing.There is a special lock & unlock button at the base of the bracket. It's shown in the Liang vs Proline test that was done.
Is there a monitor mount and powercable for the ikan vx7e/vx9e in the set or can we buy one from proline?
Hi David,
I remember ages ago someone mentioned that the docking bracket could have an attachment which allowed it to be attached to speaker stands instead of only C stands. Is that still going to be an option?
-Andrew
The production is in process.
We are working in the graphics and 3D design of the new Proline Red Special Edition, while waiting for more than 1 ton of aircraft aluminum to be deliver so we can start milling more than 15.000 parts for 50 gears.
We will update here every step of the production process .
Best regards
Luciano
Just realized something. The docking bracket doesn't seem to have a pin to hang the arm. Or was there a post about that being included?
Hi David,
-Andrew
