Peter Savage
Anyone work out what the settings should be for the GPI port when using an external trigger?
I made a manual trigger to deliver the required voltage and I set the recording mode to external frame trigger with 1frames/pulse.
The brain GPIO is set to record start with a High in and record stop with a Low in.
The LCD show the word Trigger at the lower right and the upper right of the screen has Trigger 0 frames with a grey dot .
When I trigger a pulse the dot goes yellow but nothing is recorded...
I'm sure I'm doing something wrong but there seems to be no update to the Epic manual yet to cover time lapse
any help much appreciated
p
p
