F/S Origo Record Start/Stop Button for RED One Cameras
Kennan Ward
Tent, Worldwide.
www.kennanward.com
Kennan will this work with the EPIC/Scarlet?
It may (or not as I did not test myself) work on EPIC/Scarlet with a PRO I/O module as it has the same GPIO connectors the RED ONE has...
for EPIC/Scarlet direct connection the start stop trigger needs to be powered with a battery that he original origo did not have...
so wait until viewfactor releases a new version... or try :
- the chocolat bar : http://www.madlyfins.com/product.php?id_product=17
- the pro mote : http://www.madlyfins.com/product.php?id_product=22
- to hack it yourself with a small lithium battery like I did on my aaton handle using the wiring instruction found in EPIC manuals...
attachment.php
attachment.php
Wow thanks for the tip!
Been in the field , sorry about the delay.
No does not work on Epic/Scarlet, only R1
Best,
Kennan
Hi Guys,
Andy from MadlyFins here, we're also working on a product that will (among other things) enable the use of the Origo with the Epic/Scarlet. Should be out January 2013!
In the meantime, ProMotes in stock!
