Predefined Power Grades
James B.
Can anyone recommend these or share any other good sources for pre-defined 'Looks' libraries, either free or for sale online?
Thanks!
Also came across Bob Sliga ProLooks Power Grade set . Not sure how they compare.
Considering getting 1 or more of the speed looks packages. Not sure if all the other looks are based on 3D LUTs but they seem to have good support.
Anyone use these and can recommend?
The SpeedLooks have a special lut you apply to redlogfilm before applying their speedlooks so I assume they have done their testing. I'm about to purchase them as well.
Here's a couple before and after shots. Only took 2 nodes and no corrections. Node 1 was set to RC3, RedlogFilm, then the Red Epic camera lut patch was added to get it to logC. Then a 2nd node was added, and all I did was select the Clean3500 Fuji Lut and here are the images. Obviously you could add a ton more nodes and make many more corrections, but I wanted you to see how easy and quick you get results straight out of the box.
Before:
After:
Before:
After:
Before:
After:
Wow, that looks great. Thanks for sharing this Matt.
No problem! The product is fairly new and I didn't know anyone who had used them so I wanted to post my opinion of them in case people wanted more info or samples.
